Car smokes at high rpm
Since i bought my car its bin smoking at high rpm say around 6-7ish+ here is a video of what it looks like.
http://s163.photobucket.com/albums/t311/youngrichie/?action=view&current=MOV00672.flv
This is just confirmation that you own a Honda lol
doesn’t look too bad, mainly b/c I’ve seen worse.
I just wanna know my motor isnt going
do you have a test pipe?
I dont know what that is but i have a full exhaust legal.
a test pipe is a straight pipe that takes the place of a cat… if you dont know what one is, you most likely do not have one… it doesnt look good, but if the oil level stays good and you don;'t notice a loss in performance, just be happy. these cars are old, and old honda motors are notorious for burning oil in varying degrees. In short, I wouldn’t worry if you burn less than 1qt of oil every 3000 miles, and don’t notice a lack of performance
i have a cat but my car failed smog really bad so i assume it doesnt work good
mmm check your oil level, but it looks like your burnin some oil through your piston rings
better yet, do a compression test. or a leak down. old valve seals will sometimes cause a honda motor to burn oil in vtec, if that may be whats coming out. check to see if you have little black dots all over your bumper from oil blowing out :stuck_out_tongue:
^lol black stuff does come out, after i made the video i had to clean the camera from all the black stuff oh man this doesnt look good…i guess its burning oil then
