My car sounds like it wants to turn off but it doesn’t. The RPM’s go up and down. (Vroom pause Vroom etc…) What do you think the problem might be? Please help ! Thank you:shy:
Does it do this at idle speed only. What happens when you give it gas or are going a steady speed?
itz loping eh?
check: Timing, O2 sensor, and fuel pressure.
what gas u using, and how old is the tank of gas?
when was the last time you did a tune up? (plugs, cap and rotor)
The car does not do that when I give it gas or its running only when it is stoped. After a few seconds I turn it on it starts doing this. I just bought the car so I have not given it a tune up, the tank of gas is probably old because it had 200,000 miles. The gas I put is regular unleaded. Thank you for replying so soon.
search is your friend. check your iac and idle speed screw.
Also check your coolent level…![]()
