car starts but......
I can’t figure something out.
If I leave my car chillin’ out for a long period of time (7hrs+) and go to start my car this is what happens.
  • turn the key
  • car starts but… sputters at around 150rpms for 2-3 seconds as if it’s going to die, then climbs up to normal idle…
Now if I turn off my car after that one weird start, it starts up strong with no hesitation every single time unless the car sits somewhere for over 7 hours.
any ideas? thank u very much.
(yes all tune up related parts are brand new such as the fuel filter, cap, rotor, etc etc etc)
DAMN…
-Battery???
-Injectors (pulse width messed)???
-ECU???
-Loose sensors or connectors???
I dunno bro…Call me…
L8rs…
Re: ???
Originally posted by CVG2
[B]DAMN…
-Battery???
-ECU???
L8rs… [/B]
yeap, i’ve checked all that. thx though
SHIZNIT…
How long has it been doin it???
Maybe juss wait and it mite go away :slight_smile:
fuel regulator
the fuel regulator may be bad and letting fuel return to the tank when it is sitting. Thus when you turn the key on again it has to try to build up fuel pressure again and starving i out then on your second time the motor is “primed” if you will. Test it by turning the key on for like 3 sec but do not turn it over. Then turn the key back off and then try to start it, if it starts just fine that’s what i would suggest replacing
Re: fuel regulator
I’ve tried that already aswell. thanks.
hmm my bad, i should have made a list of stuff i’ve already done… but then again that list would be insanely massive hehe.
:slight_smile:
[B]SHIZNIT…
Maybe juss wait and it mite go away :slight_smile: [/B]
lol bro, no half ass jobs yo, i’m jap, I’m not allowed to do that:)
Guess u checked all the vaccumm lines huh???
Ur fuel lines runnin under the car ok physically???
Shiznit…Sorry if im frustratin ya brova :whoa:
[B]Guess u checked all the vaccumm lines huh???
Shiznit…Sorry if im frustratin ya brova :whoa: [/B]
hmmm… I haven’t check the fuel lines underneath BUT… it’s strange how it only does it after it’s been sitting for a while.
something to do with it just chillin… maybe my car likes to chill a lil too much when it’s not running… hmmmmm
my car does that but I think its my FPR
I had that same problem with my teg before i sold her. It would only do it in the mornings or when it was cold out sitting for a while. Im not sure if you replaced your coil but you might want to try that. I swapped coil and plug wires out with some brand new ones and the problem went away. Not sure if that would work for you but you might want to try swaping those parts with a teg thats not having the problem and see if it helps or works.
yes the coil has been replaced too :slight_smile:
Fuel filter or perhaps the fuel pressure regulator. What about timing, everything in spec? Weird stuff man.
Already have a new fuel filter on…I will swap the FPR and double check the timing. Thanks Dan.
Haruki, I had the EXACT same problem with my Civic EF/ B16A swap. Didn’t really think too much of it since it only happened when it was really cold and only for 2-3 secs. I noticed the problem started after I had the Integra throttle cable installed.
-kris
