car stereo/ inside lights/ defroster not working
as the titles says, out of nowhere my stereo stopped working, so did my overhead lights and the defroster doesnt turn on.
the dash lights work the head lights work and hazards work.
anyone have any idea what it could be?
i already checked the fuses under the hood and under the dash…
thanks for any info!
sorry i just found a thread about this :slight_smile:
i did find the thread but there was no post looking into this problem.
i need helping figuring whats up.
i checked the fuses under the dash and under the hood but they all are fine.
it sucks not having a stereo!!!
thanks for any info
Recheck fuse 14 - 15A, [hot at all times] in under dash fuse box, don’t just eyeball the fuse test it with a meter or test light or just replace it with a new or known working one, [swap it with another 15A fuse in the fuse box.
Both the radio and dome light are on fuse 14, not sure about the defrost, it is on a switched circuit so it’s not fuse 14, [hot at all times] but fuse 14 may be powering something in the ICU, the defrost relay control, [timer] is in the ICU.:shrug:94
i checked them all with a tes light and even replaced them.
i forgot to mention that the dash clock doesnt work either. i was looking under there today and noticed a click everytime i tapped one of the connections (top right, had most of the wires in that connection and had a blue “connector end” instead of the norma white ones.) when i heard the click it seemed like something kept turning on and off.
thanks for the help, ill recheck them tomorrow. :slight_smile:
