car stopped at idle. Need input PLS.
Yesterday, I was at a light with my AC on when suddenly my engine stopped. The rpm gauge was slowly going down to zero and the car shook a little when it stopped. But it started up normally. It usually idles fine at 750. Never had this problem. Can someone give me list of things that could be bad? Thanks.
No G2 guru around these parts?
ignition
Check all of your ignition accessories and timing. Spark plugs, wires, cap, and rotor to start. You can adjust the idle speed and ignition iming if that helps.
If there is a check engine light then follow the teg tip to get the code. If you still have the problem then report back and we can go from there.
Note: I am no guru by any means.
Thanks guy. I’ll check those things on the weekend and let you know what up.
