Car wont even crank plus code 8 tdc sensor
What’s up fellow g2ers Ive been having trouble late lately with the car not wanting to start actully it won’t even crank and it is throwing code 8 witch is Tdc sensor circuit I was wondering if anybody has encountered this problem. Before the problem started I would have to hold the in start position for 5-7 seconds maybe longer. That’s really all I can say about the problem. But have read on some other sites that it is the distributor being bad so im gonna replace that tonight if anyone has anyinput on this inwould really appreciate the help. Thanks again NpG2Da
pretty common. distributor it is
So I replaced the distributor also replaced the starter still having trouble I think it’s got a loose connection or something any able to help please reply
interesting. so what exactly happens when you try to start it? cranks, but no start? no crank at all? are you getting the same code still?
No crank at all code 8 sometimes comes up really only happen when I try and start it in the morning when it’s cold so I jiggle the wire on the connector at the distributor and then it will crank most of the time but sometimes it takes longer for it want and crank
it should still physically crank. that should have nothing tyo do with the distributor
Yea I’m pretty good When it come to diagnose this car but this one has me pretty boggled checked battery volt and alternator and all the voltage checks out
try jumping the starter directly then. see if that works. if it doesn’t, the starter needs to be replaced. wouldn’t really explain the tdc code though
Could it be possible the timing jumped and the valves are hitting?
he says it’s not even cranking. gonna be either the starter, relay, CIS, or ignition switch. or wiring between any of that.
when you try and start it, and it doesn’t crank, do you hear a click at the starter?
The starters is good jumped it before i put it in… this morning it fired right up. What is the cis
clutch interlock switch
