I’m pretty new to the Integra scene. Thus far I have done some simple things to my 92 Integra and it’s had a few problems that I’ve been able to diagnose and fix myself but now I am just stumped.
It first started having troubles a few months ago, shortly after I got it. I ended up getting the battery that was in it checked when it first died. Was shot, so I purchased a new one. A week or so later, it was dead again. So I ended up getting the alternator checked and I needed a new one due to a bad regulator.
So I got it, registered here for a little alternator help (and might I add removing the left driveshaft is NOT required to replace the alternator
on a DA ) along with replacing the battery fuse which was blown and sailing seemed smooth.
A month or so went by until it randomly started having electrical problems. When I brake my stereo would cut out so I took out my deck, pulled the ground from my trunk and made sure no faulty wires were the problem.
Around Tuesday I went to Best Buy and left my lights on (I know… save it! lol) and somebody jumped my car and I was able to drive it the rest of the day with no problems. On Wednesday my car failed to start for work, thankfully my driveway is on a hill, so I rolled out popped the clutch in reverse and went to work. In the week leading up to this, there has been a great delay in the car firing up! It hesitates for up to 5 full seconds then fires up just fine. After work it failed to start again… someone jumped me and I went home. THIS morning it had a delay but actully started up on it’s own, only seemed to want to die but I just punched it and went to work, SAME symptoms on the way home.
I can’t seem to diagnose this problem for it is not consistant BUT it has been getting worse seeing as my car won’t start at all right now. It will not even turn over.
I have no idea what to do, I don’t know if this is a short or what… if someone has a good indication as to where I should start… It’d be greatly appreciated.
-Dustin
