car wont start the normal way
o okayy thanks i just wanted 2 start it and move the car… nd i was affraid that starting it like that could damage sumttin… but i guess not… thanks… i’m gona replace the distributor and hopefully that will solve ma problem
Last time I checked, the ignition starter wiring did not run thru the distributor. If your car runs after jumping to the starter, then the distributor is operational.:salute:
o yea… .but could it be that theres a senseor gone bad in the disriputor… the tdc sensor… ??? becuase thats the code it was giving before it stopped giving a code
ahahahha finaly i got the problem all sorted out … the problem was that the jumper where i used 2 connect 2 the battery 2 jump the starter is actuly the lose wire ahahhahaha
now itz all working no problem
the clutch switch may have gone bad, or the little rubber button on the clutch pedal dryrotted and fell out or just broke, it happened to me… you can look under the dash and push in the switch and try starting the car
lol man i don’t think u understood wat i said…i said i solved the problem it was just the wire that connects to the starter that was loose and my car is auto lol by ya itz working right now no problem
Wow, 28 replies, an MAhgawdji finally slaps an ice cream cone to his forehead.:fingban: The lobotoraters should have cut this loose a while ago.:werd: Oh, well. Its beer thirty, gotta go.:slight_smile: Although he holds the record for page one.
well u made ur point ur drunk lol
Well, my three friends and I are only on the second pitcher and the consensus is that we’re not quite there yet. Perhaps you’d like to step over here and diagram on the chalkboard what your saying. LOL!:blah:
