i have a 92-93 fullexhaust set up on my 1990…and it was too long so the muffler tip sticks out crooked and leaning against the bumper basically…im sure if i got a shorter cat(90-91) it wuld pull the exhaust back some more and the muffler(axleback style) tip part wuld b lined up stragght?
how are the bends that go over the rear lower control arm? cause the piping goes over it, so if you would shorten the piping from the front, it will cause that part to pull forward, and if the cat wasnt the problem, you would have a major problem with the exhaust piping rubbing/hitting your rear lca. expecially if your lowered with an aftermarket exhaust…
the piping wuld still go over it
I’m having a problem finding the right size cat. I think I have 92-93 aftermarket header on my 91 integra. The O2 sensor is on the header. I have a greddy sp2 installed. Now there’s a distance of 22" from the header to the exhaust. I’m having trouble finding a direct fit cat. What should I do?
just get a universal cat and go to a muffler shop if you need a quick fix :shrug:
