Causes of low oil for recent swap?
There’s about 2000miles on my recent B20 swap and my oil is already low (as indicated by the oil pressure light and dip stick). Prior to the swap I’ve replaced almost everything possible to prevent any oil leak…however nothing was replaced for the head or block (can void the warranty of the motor if I do open it up). Using mobil-1 5w30 fully synthetic.
Oil pump, water pump, seals, oil pan, I/H/E gaskets, etc to name the few. Only upgrades to the car are the DC headers, NGK iridium plugs, some spark plug wires by VMS, and a high flow magnaflow cat.
Any guesses on what could have caused the drop in oil? I haven’t taken a closer look to see if there are oil leaks but last when I was under the car there weren’t any visible signs of fresh oil, pretty dry if you ask me.
my oil pressure gauge indicates:
idle: 25~30psi
driving: 80~85psi
thats what my oil pressure guage reads, thats good if you ask me. if the oil pressure light is on it could be a faulty sensor. and if there are no external leaks then it must be burning the oil, see blueish smoke out of the tailpipe at all?
no blue smoke. purely white. Might re run the compression and leak down test to see what’s up.
Also saw some minute oil leak from the oil pan bolts. Retightened some of them hopefully that makes a little difference as well.
edit: should I run 10w30 instead to prevent the oil being burnt up…or wouldn’t it make that much of a difference. The motor has about 45k~55k.
it might be best if you stay away drom full syn oil, since it tends to make even newly built engines leak after a short time.
youi rbest bet is to jack up the car and sit it on stands and go over it with a fine tooth comb for any leaks. my swap did the same after I drove it home fresh from the shop and i never really found anything, 3months later while doing a tune up I pulled the spark plug cables out and found them drenched in oil. Someone have removed my valve cover gasket and spark plug tube seals, yoiur oil filter could be loose. if your engine is already wet from old oil then go to the public car wash and wash it down to find new or current leaks.
I do the same and even take my jack to pull the wheel off and really reach the back of the block on the driver side.
Synthetic oil does not cause newly built engines to leak. Manufacturers use synthetic oil in some engines right from the factory. Whether synthetic or not, at the same grade and under the same conditions, you would use roughly the same amount of oil. If you are running at high RPM all the time, the engine will burn a bit more oil than usual. A quart or so every 1000 miles is not out of the ordinary. You seem to have checked everything so I think you are on the right track by re-checking compression first and see what that yields you. You can’t be sure you didn’t get a poor engine but 80 psi is pretty high oil pressure. You could try 10W30 as long as you aren’t below about 50 degrees F outdoor temperature. I would be interested to hear the type of driving you did on those 2000 miles.
