CD deck goes out after installation
OK…if anyone can help me out or point me in the right direction, i’d appreciate it. well… i decided to put in a new cd deck, so i unhook all the wires from the back of the old cd and proceeded to hook up the new cd deck. i don’t know if this is where i f’d up on or not…but while connecting all the wires from the back of the new deck, i left them as is…no electrical tape wrapping the wires because i just wanted to test it out if everything is correct before taping them up. Well…everything sounded alright except for there being a bit of static, and then all of a sudden the front speakers goes out…then bam, nothing…everything shuts off. Now i can’t power up the deck, i checked the little fuse on the back of the cd deck and it’s fine. SO… what do you guys think went wrong?? where should i look to find the problem??
Did you use a smart harness? That would be the easiest way to install these.
Let’s hope all you did was blow one of the oem radio fuses,
fuse 14 - 15A and fuse 22 - 10A, both are in the under dash fuse box.
If you did not just blow one of them, then you have blown the output stage of the new HU.:tsk:94
