whats up everyone well to start off i have a 90 rs with b16 with jumper to obd1 so i been looking around about this cel but the only thing i found was that if something wasn’t plugged in all the way or if you got a bad fuse box you’ll get this cel but i seen a plug missing to my fuse box it was the one wired plug with white and red wire does anybody know what these goes too if anybody can help thank you and this is my first tread so my bad if i did anything wrong
my bad spikeymike i was trying to put it on the right category and delete it
someone please help
post pictures of what your talking about…
not sure what the wire goes to. I dont have any wire schematics around me at the moment, but Code 20 is a problem with the ELD.
The DA doesn’t have a Eld so unless your running and aftermarket ecu and tuning program that will allow you to turn it off, youll just have to ignore it.
okay thanks but even with my p75 that i had with my b18 in it it did the same thing but if you can can you please try to find out what that goes too thanks a lot for the help man
