Hey, I recently rebuilt my b18 for boost and the car started fine and idled. Recently the car wouldnt start and i figured id leave it alone until i get it chipped, I got it chipped plugged it in and still nothing, I recently noticed the CEL flashs twice on ignition 2 then goes out and when i connect the jumper to read the codes my light stays on…I checked for spark its good, checked fuel pressure its good. I noticed my injectors werent working so i checked all connections and i pulled them out of the manifold and layed a piece of paper underneath them then tried to start it, it sprayed about halfway down the paper( it was horizontal) so i put that system back togeather and tested each clip while ign. 2 was on and got 11.2V across all four, I then checked my main relay and some connections looked poor so i resoldered every connection and put it back, I`m out of ideas here, I thought the problem was fuel but after seeing the CEL flash twice when not jumped and stay solid when jumped i am starting to worry about the ecu, I also checked the ground at the thermastat. Any ides would be appreciated. Thanks, btw its a 1992 teg rs 1.8L non v-tec with 520 cc injectors and a fpr.
I would change out the ECU with a know good stock ECU.
most of the time that happens when the ECU is bad…or the car is in limp mode…but i dont think obd0 has limp modee…swapp ecu’s first and see
Hey, so no more flashing CEL when i go to ignition 2, the light remains on with the others. The only thing i could think would change it was when i removed the injectors and unplugged the sensor on the IM by the fuel return hose. Im getting intermittent periods when the injectors will fire. I
m trying to rule out everything else before i have to find an ecu, I live in a small town and acura parts are very limited, any other places to check
I would change the ECU
