Well, pgmfi is basically worthless, i’ve asked about this problem on two separate occasions…got a good amount of views but not one response.
I have a 92 Integra LS/vtec with a b18c1 head. I’m chipped on a pr4 with the vtec conversion using Crome. The car runs fine and vtec kicks in…but when I’m around 90mph or leave the car in high revs for a while I get a cel. I checked it and I’m getting a code 20 and 22. Electronic Load Detector and Vtec malfunction. Now the thing is I disabled the ELD, so I don’t see why it’s still reading it, the g2 integras don’t have the eld. I tried reburning it a few times just to make sure since I know that sometimes the programs don’t always get burned correctly…but I’m still getting the same CEL codes.
Problems I’m thinking it could be:
-Crome isn’t disabling the ELD and needs to be a certain setting for it to work with my pr4 ecu…
-Not enough Oil…I don’t know how much a b18c1 needs a far as oil, I put what my manual said for the b17, too much oil is not a good thing so I didn’t want to go with anymore than I should. Maybe it’s enough pressure at the lower speeds but not at higher speeds, but I would think it would have more to do with the rpms for the pressure. But still doesn’t explain it reading the disabled ELD code
-I wired up a Vtec light, i’m wondering if it’s taking away some of the current to the solinoid making it not function correctly since all the power is going to keeping the motor up…I don’t have a resistor since the tutorial I used said you didn’t need one, but i’m thinking it might, or I’m going to have to take it out. But again reading a disabled eld code
I tried reburning it again today but it’s still stuck on giving me the same codes. And it’s on a completely stock p72 basemap. All I did was disable knock sensor and eld. I know some people have been saying on other threads to disable the o2 heater sensor, which really sounds like a stupid thing to do.
