Center Console Block-off Thread
What do you guys do to block of your center console and dash after removing the radio and all that?
Reason is that i removed my fan/temp/vent control, center vents, radio, ashtray and lighter. Im not 100% on how to block off the gapping hole in my dash.
Heres what i have going for now but im not sure i like it. Its walnut with a walnut stain. If your wondering why wood, its because i think carbon kevlar would be ugly as hell and dont have any other ideas.
Post up oppinions/descriptions/pictures/suggestions
My opinion is that looks ugly as hell. I have no idea what you could use either.
what about some brushed aluminum???
Yeah that sounds like a good idea. Maybe black brushed aluminum?
i was thinking just aluminum but the black brushed sounds even sweeter :rockon:
i have on ? what is that over shift boot for by your tranny shifter???
black brushed aluminium :rockon: Where could I find it?
Its an adjustable brake proportioning valve
i like that stealth tach. is it a multi-guage tach or does it only do RPMs? whats the LCD for?
shit just tell me who makes it, i want one anyway ahah
I think the center might look cleaner if you put the pocket at the bottom back in. Then stopped the plate where the ashtray was. Then paint it flat black or cover it with some fabric.
the tray is terribly useful too, maybe not so much on a track car, but having somewhere to stash change for tolls is nice especially since there is an AFR display where the coin tray was.
also lends a bit of aesthetics to the interior as opposed to a huge plane of brushed aluminum
Not sure of a reliable place to buy black brushed aluminum but I googled it and this came up http://www.formica.com/publish/site/na/us/en/index/metal/colors_collections0/metal_laminate.html#
Thinking of the fabric idea reminded me that i have a huge sheet of matte black sticker material. What do you guys think of that.
Its for a track car so i wanted to remove the coin tray and all that since i wont be needing any of it.
The tach is a SPA and the lcd shows boost pressure.
You could also do the black abs plastic they make gauge panels out…they sell it on ebay in sheets and it can easily be heated and contoured to fit nice. Also its cheaper and lighter than the aluminum.
haha ive never seen anyone wood grain it… get a wood wheel to go with it
just paint the wood black . problem solved
check out leos he didnt block off the radio though
http://g2ic.com/forums/showthread.php?t=201783
I think the idea is really good but the wood finish isnt really my taste, maybe if you sprayed it with semi-gloss blk or just flat blk.
you know I found on youtube some vids on how to spray paint carbon fiber looking finishes. its like a 4 step thing and looked easy maybe you can look into that.
http://www.youtube.com/watch?v=Y_dLALTjbyM
Here’s my contribution:
It’s lexan with a vinyl carbon fiber look overlay:rockon:
please pardon me for for asking, but why block off?
I can only speak for myself, but the reason(s) were a, to cover up the now non-functional under dash ventalation system that was removed, with somthing a little easier to look at, and b, to have a place in the center of the dash to easily view the remainder of a soon to be 5-gauge panel, where as the side vents are just blocked off for cosmetic reasons:D
oh. ok. if you’re using the area for gauges, then i see the point
