the visor looks very nice but i dont like how the bolt an washer stick out like they do in the pic. I think if you could make it flush mount say like oem door visor it be perfect . Maybe put a flat piece of metal on the bottom of the carbon fiber were it mount to give it strength when there made to flush mount a small screw. just my .002 in it
^ I agree that does seem to stand out. I think if you could get black bolts and washers, it would look a lot better. Also, would this mounting hardware be compatible with the OEM Visor? And if so, how much would an extra set be?
Actually, he did mention about getting black bolts but I kinda talked him out of it for others who may want to paint it other colors. But it’s true black bolts and washers would make it look better. Also the bolts on the side were 1/2 inches too long and will come with shorter ones.
Another sidenote, I took the freeway going home and I double checked once I got home and the visor held nicely. No play or movement. Everthing was nice and thight.
And yes, the brackets will be compatible with the OEM visor.
i really like them an the only thing holding me back from get one is the screws . They take away from the clean look. I think if you had a counter sunk screw in it say like oem door visor it flow way better an look way better my .002 an only thing holding me back
