change timming belt car no start
Changein the timming belt on my nephews 93 integra.
all done no spark. I rotated the Eng everything lines up. I even took it apart to check them again, I also check all the fuses.
Iam stuck?
did you change the cam seals as well? only thing i can think of (aside from sheer coincidence) is that you may have forgotten the cam key way(s).
you do anything else besides the timing belt?
just the water pump and the…
i have no power at the distributor
you have a multimeter?
i need one all i got i a power probe
found it the coil was bad…
I had change the igniter 3 times
glad you found it.:rockon:
