changing master cylinder on anti-lock brakes car
It said in the manual that I need to relief pressure from the line with a special tool at that thing under the battery area. Honestly, how much pressure could there be? Can I just losen the lines at the master cylinder and let the pressure relief from there?
I changed mine a while back and did nothing special to the ABS. Just loosen the lines at the Mast Cyl and you will be fine.
The ABS system will not be pressurized anyway unless you JUST parked the car after driving it. Either way, it’s not like the pressure is going to be so much that it send you flying across the yard!!! :rofl: they exaggerate things SOOOO Much.
sounds good to me.
now, if I can just find the time for this… If I don’t have to work again this weekend… maybe I just might get to…
