Just a quick question is there anything i should know before i change out my rear pads? anything that i need to buy before i get to work on it…? thanks
nope, I think you are good to go
your basic tools will suffice
It’s not a bad idea to have the tool to twist the caliper piston back in. The book says you can use a set of needle nose pliers but one of mine was a little rough and it was hard with the tool and a 3/8" ratchet so it would have been imposible with a set of pliers. Other than that its basic hand tools.
ok cool thanx guys.![]()
if you have a gasket scraper thats what i used to twist it back in, looks like a screwdriver /flathead with a wide end on it
