changing to power door locks
What would i have to do to change my manual door locks to power door locks. I know i need the new panel but what about like wiring into the fuse box? What else is required?
try searching “power windows conversion” or something near that. u’ll find quite a few articles showing exactly what u need.
I did mine without any of the stock stuff and without touching the fuse box. Bought the generic actuators off Ebay, 2 relays, some wire, drew power from the cable I ran to the battery for extra stuff. I never installed a switch, only way to use them was through the alarm fob.
I want to make it like stock though. No extra wires coming from battery and shit. I want to do it up just like it was from the factory. Any suggestions on what all will be required. The forums i found are just quick hack jobs.
I do realize that it would be a good amount of work
buy some da doors that have power windows n everything already on it. then all u gotta do is take care of hooking up the harness
Most DAs have power windows, power locks are less common.
I’d recommend getting the Helms manual and looking into everything needed from that if you actually want a factory conversion. I wouldn’t be surprised if it required modifying the fuse box (adding connections for fuses/relays) to make it truly factory.
I’m actually doing this as well and i noticed that the wiring for the module by the fuse box isn’t there. Either that or I missed it.
i would like to do this too…
how much would whole doors cost? a good price?
