i believe it was 25 it said if anyone knows! emler where u at man! hehe thanks!![]()
i just check, there is no code 25.
0 - ecu
1 - o2 sensor
3&5 - maifold absolute pressure(map sensor)
4 - crank angle(crank sensor)
6 - coolant temp.(tw sensor)
7 - throttle angle
8 - tdc position(tdc sensor)
9 - no.1 cylinder position
10 - intake air temp(ta sensor)
12 - exhaust gas recirculation(egr)
13 - atmospheric pressure(pa sensor)
14 - electronic air control(eacv)
15 - ignition output signal
16 - fuel injector
17 - vehicle speed sensor
41 - oxygen sensor heater
43 - fuel supply system
Re: check engine code 25
ECU code 25: error code: problem: a fan of the sacromento kings.
To fix the problem, buy a Laker jersey and your car will be all better.
screw u pal! hehe:up:
