well the enginge has never given me any of the out of ordinary problems but suddenly my check engine light is on ? wtf could it be … all fluids are fine … but one thing is that i think my tranny is leaking fluid could low tranny fluid cause the check engine light ? its a 91 GS 5 speed … well i checked anything i could think of ? any help is appreciated … car still runs like a champ but once in a great while it will just shut off on me and it wont start but then like a few seconds later it will …well thanks guys
check the code then report back. nobody here can do anything for you without that
iam pretty good with cars and all but no clue how to check the codes?
how exactly would i do that ? i never had a situation where i had too
http://www.g2ic.com/tegtips/engine/13.html
in the future, searching will usually get you your answer faster
sorry … dealt with it it is just a code 17 my vss … no big deal i think i will buy a new cluster after i replace the vss haha … yeah i was going to look it all up in my manual but couldnt find it but i found it a little after i posted this
no prob, glad to see you figured it out
And you probably don’t need a new cluster, the VSS cable probably just pulled loose from the receptor at the back of the cluster.
i just want one lol
