Chirping Noise, passenger side axle.
Hey guys, so I’ve noticed this chirping noise around the passenger axle side. It is speed related, it chirps faster at higher speed. Doesn’t really make the sound when at a full stop, occasionally it will make the sound when stopping briefly. So i replaced the entire passenger axle anyways since i’ve been getting this leak, thinking it was my axle seal. Turns out axle seal is fine so I didn’t replace that(wouldn’t fit anyways). Oh and my CV boot was torn before too. I thought this replacement would fix this noise but turns out it didn’t. Still chirps at same rate, i think its a little quieter but still a nuisance. Is this a lack of lubrication? loose part? I’ve heard vaccuum leaks can cause some chirping sounds. I don’t think its a belt since it’s coming from the right side, i could be wrong though.
Oh and idk if my transmission is not stock or the auto store did me wrong, but the axle and seal weren’t the same as what I had. The axle was only like 1/2 inch shorter on the outer side but it fit nice and snug( is this bad, doesn’t look like it leaks and car drives fine) .the axle seal wasnt the right size either so I didn’t use that and just stuck with what I have in it. How can I determine what tranny I have? I bought the car some-what modified. Only numbers I found was the sticker on the top of the tranny near the engine stamp. A1-1042192
First, is your DA equipped with ABS? If yes, then more than likely it is your ABS power unit. It is located underneath your battery, along your fram rail. I have the same problem… Every now and then, it makes a squeaking sound, like a loose belt or something. Still haven’t figured out how to fix. Anybody else?
yeah I do have abs. I’m thinking of deleting abs anyways, still reading up tho
Any updates on this? My car is doing the exact same thing. And I’ve been suspecting the damn abs also. it’s like an annoying mechanical whirring noise/ Chirping and it happens every couple of minutes but it’s been happening more and more recently.
nope no idea. Haven’t noticed it recently. but its gonna come back for sure.
it might be the dust covers behinde the rotors, or just a bad axle.
I had the same problem, when i would drive there was a Chirping Noise and when i came to a stop it was gone…well i did some research and talked to a fellow G2 owner and it was the speedometer cable so you might want to check that out dude
