i have a 91 gs and everything but my cigarette lighter is working. i checked for power on the relay and it has power but where the cigarette lighter plugs in it doest have power. is there some way i can fix this and if not what do i need to replace? i checked all the fuses and replaced them all today.
it could be that ur cigarette lighter is already burnt out. i suggest that u try replacing it… then go from there. or u could have a burnt up or broken wire leading to it.
you have power out of the relay, now what about at the cig lighter itself there are two wires hooked up to it check that you have power there at the wires if you do then the lighter itself is burned out like squeezethis said
fuse
u obviously didn’t read the original post.
