Ok I am going to put some city lights in my head lights (oldschool days) but I for got how to wire them up. I know I want them to with the parking lights are on an go off when i turn on the head lights. Sure I need a relay so if some one can tell me how to wire it up that be great thanks
#30 of relay from park light circuit, [park light free pin on under dash fuse box].
#87a. to #30 of second relay.
#85 to chassis ground.
#86 from head light circuit. 94
Ok thank one question what wire on the headlight circuit (color)
Low beam is red/yellow and high beam is red/blue at light switch
After fuse box red/green is high beam and red/yellow is low beam.
I just thought of something, you are going to need two relays, one to cut power to the "city lights when low beams are on and one when high beams are on, as the output from head light switch to dimmer switch is internal
So wire first relay like above except #87a, instead of going to the city lights connect it to #30 of second relay.
Second relay wiring…
#30 from #87a of first relay.
#87a to city lights.
#86 from high beam circuit.
I will edit the first relays wiring. 94
where did you buy the city light kit?
i got is at a shop up here in northen cali. It was an h4 kit but i made it work ill post pics next week . THANKS FCM IT WORKED GREAT
