Civic Type R Cluster
Does anyone know how or if you can install a civic type r guage cluster into a 2nd gen or what modifications you have to do to make it fit and work…because i have a civic type r cluster laying around and i was wondering what you need to put in a g2…PLEASE HELP!!!:bigread:
in order to make it work, i guess you’d have to change the speed sensor… beyond that, i don’t know.
What year civic type r cluster are you talking about? Wiring should be easy. You just need to find a wiring diagram for the color codes on the wires for both vehicles. Then cut your plugs off and wire up the new plugs. The pins on the da plugs are probably not the same for the civic plugs. I know they aren’t for the 94-up integra. Hopefully it came with plugs with some wiring left. If not you need some. I would guess usdm civic plugs should work. Maybe a few wires might be different. You need to swap out the speedo cable to a vss setup like in the 94-up integras and newer civics. If you are going to keep your power steering I heard a vss out of a 90-93 accord has the ps lines on it so that should work.
I put a 97 jdm itr cluster in my car. Here’s the thread. http://www.g2ic.com/forums/showthread.php?t=120646
Thanks
i was wondering where did you get your finished bezel from or do you know where i can get one
