Has anyone tried to do this? I have seen some new Infinitis and stuff with clear plastic and red bulbs. Does anyone think that this is possible to do?
I just need to know if I can buy clear reflective plasticlike what is already in there/
just take out the red peice and leave it like that .
the rear window can act like the lense
you suggest removing the lens cover? What happens is you get an anoying bright glare everytime you brake. I believe the brake cover is one peice, so if you just remove the red lens part you would be ok, but I believe it is all one piece.
go to home depot or find a friend(or take it from your local grocery store bathroom) and get a sheet of that overhead halogen light cover(can’t remember what it’s called exactly). remove the red lens from the brake light, then cut the shape out of the light cover, then glue the light cover where the red lens was.
~Lance
Hey, that light cover is a good idea. Maybe I will try to find a small piece so i dont have to buy a whole sheet.
