i jus got clear corners. does ne1 kno the easiest way to put them on. if so could u please explain for me thanx.
Open the hood. remove the screw that attaches the cornor lens to the head light housing. put the palm of your hand flat on the lens and put a little pressure on the lense while you pull out. the lens should pop right out. Untwist the lights and install your new lens.
- Pop the hood
- Locate the screw holding the stock one in. There’s only 1 and you can easily see it.
- Grab it from the back (where it meets the fender) and gently, but with a lil’ force, pull on it. You might have to wiggle it a bit… It should slide out.
- Reverse to install!
HTH any questions let me know!
Dev
