Clicking noise after breaking Help ASAP
Hey all,
I just recently put tokico Illumina’s and Eibach sport line’s also replaced an outer tie rod (driver side) on the car
Now i have noticed after breaking heavly or just breaking alot in a short time i get this ticking noise i know for sure its not the enigne cuz i have had the car off while this is happening. it sounds like something is hitting something and its rotating because the faster the tire moves the faster the ticking goes.
Any one have any idea what is happening?
Not sure exactly what the problem is, if the clicking also happens while your turning then your CV joints may be busted, which means you need some new axles. Since you got the Sportlines, which are like a 1.8" drop right, you should probably think about a camber kit, which would save a lot of stress on your axles and other joints in the future.
I think i know whats the prob and its not the axles.
I think the break pad became loose some how and hitting the rotor. i know i need to change my breaks cuz there getting pretty low.
This problem happens when i am hard on the breaks not turning. but thanks anyway.
