Whenever I take a left turn, there’s a clicking noise from the right suspension and I’m pretty sure it’s the CV joints.
How do I confirm this? Is there a way to pull the tire similar to how you test tie rods?
If I do need new cv joints, what do I ask for… I saw at autozone.com that they have both the “CV HALF-SHAFT” and also a “CV JOINT & BOOT KIT” Which one should I get?
yes its your cv joint. Crawl under your car and look, you can probably see the boot is torn and the grease is everywhere. I would probably buy the kit, but changing cv joints is a PITA, so you may want to look for a used half-shaft. Check thepartstrader.com good luck:)
