clicking sound
I noticed the ABS light started to stay on when I was driving. And when the ABS light turns off it starts making a clicking sound really loud. It keeps on turning off and on over and over. I found out my brake fluid somewhat leaking out a bit. But can someone give me some help on another direction to figure out what’s wrong with it. It’s also a 92 gsr.
Dude, you got to be a million times more specific. ABS light is a start. You can pull the code to find out why. Sounds like you checked the basics like fluid levels @ both reservoirs, but where is the fluid leak? Clicking + an ABS code could mean something with a drive axle. I only suggest that because the teeth for the sensor are pressed onto the outer driveaxle joint… but I could be totally wrong so…Does it click in a straight line, or only when turning…or whenever it feels like. Does the sound seem to come from the front or rear?
It starts clicking right when I start driving, but it stops later on when the ABS turns back on. The sound keeps coming from the passenger side.
