clicking under the hood in my 91
Just did a motor swap and moved some wires around, I moved my injector box down and now when I turn the key to on, it click, (at least sounds like its the box,) when its bolted to the fire wall in the stock spot is that basically grounding the box out? New to this whole thing, anything helps thanks
It doesn’t have to be bolted to the chassis/body for ground. I did a wire tuck and relocated mine under dash and just zip tied it and it ran fine. I have since converted to saturated injectors, and got rid of the box though.
Ditto the above^^^ what was the swap and what injectors are you now using? 94
its about 2:30am and my dad woke me up and told me my car was making a clicking noise. i came out side and sure enough it was cliking. i disconnected the battery and i could smell somthing burning. not sure what. but when i disconnected the battery and all was fine. i have to say, this is SUPER WIERD. it just heppened now. im wondering if the car is still driveable at this point? what is the problem? HELP! i have to drive to school tomaro!
Are any wires getting hot to touch. And sounds like something has to be grounding out or an electrical issue. Your resistor box should not ever be clicking. has to be a relay or switch or sort making clicking noise. Your going to have to track it down.
