does anyone know if there should be a light behind the LCD that displays the set temp in the Digi climate control cuz i cant see nothing at night there
also the manual setting i know it has the cover but are the different settings sposed to light up…i mean the actual picture itself and not the lil green LED above the picture cuz those work… im gonna try and restore these lights…if only i knew how to get the dman thing off without breaking anything.
nice car once again…to get behind there, you have to take off the plastic trim piece (the part that goes around the gauge cluster and all) <<<search…its been discussed…then after that is off, you will be able to remove the other parts and take apart/change bulbs…
