climate control not working
a couple days ago I got into my car and it was baking outside so I pressed the a/c button and turned the fan to the 4th click. I heard the a/c pump come on and the cars revs went up. However no cold air blew out. If i switched it from recirculate i could feel the a/c seep in, but not enough. I checked every fuse in the foot well and none were blown. What could the problem be?
Thanks in advance,
Miles
sounds like blower motor or the switch went bad, its fairly common from what i’ve seen have you tried searching the forums theres quite a bit of threads on this issue.
I found the removal process and how to clean or replace the blower motor, along with the three pages of discussion on team-integra. However, I was wondering if there was a way to diagnose what the problem could be exactly.
