cluster light doesnt turn on?
first switch to turn on head light and for taillights but doesnt turn on?
-but head lights work
-fuses under hood is okies
is it some other fuses else where?
[QUOTE=tino;2200599]first switch to turn on head light and for taillights but doesnt turn on?
is it some other fuses else where?[/QUOTE]
Can you please try and explain a little better? Your not making any seance at all. Be as clear as you can.
It makes perfect sense. :roll:
Why not just answer his question. And you don’t need to quote him. Your post is right after his. :bang:
There is the interior fuse panel located in driver side kick panel. Fuse #11 is for the cluster lights
yes i checked the fuses down there and its okies
mayb eletrcial problem tat its grounded?
[QUOTE=spikeymike;2200604]It makes perfect sense. :roll:
There is the interior fuse panel located in driver side kick panel. Fuse #11 is for the cluster lights[/QUOTE]
This makes sense to you??
-but head lights work[/QUOTE]
I would of helped him but didn’t understand the problems he is having. He said the headlight and tails don’t work on first switch,but the headlights work??
I wanted to get more info first before telling him to check a simple fuse,not just tell him where a fuse is and call it a day:roll:
Might not even be a fuse for all we know,and i quoted him so he can reread his post to see what i was talking about it not making sense.
[QUOTE=tino;2200629]yes i checked the fuses down there and its okies
mayb eletrcial problem tat its grounded?[/QUOTE]
What exactly is going on bro,so we can help diagnose your problem,be as clear as you can please.
Are you saying the headlight and tails work but the cluster lights don’t? Might be a fuse or the dim switch.
its the switch to turn on cluster/talilights/and front signal light before you turn on the headlights
and i checked the fuses and there okies
Now the headlights do work on the 2nd click? But the cluster lights don’t work at all right?
Ok,have you checked the dimmer switch at all? It might be turned down or not plugged in.
Have you done any work at or around the cluster at all?
Yes the headlights do work
dimmers is all the way up and i pulled out dash and its plugged
no i havent touch the cluster but plan to swap to led
gotta get it fixed first
Umm,so when did this start happening to you?
Have you been taking the dash apart when this happened?
If so,the fog light switch and flasher switch needs to be plugged in along with the dimmer for the lights on the cluster to work.
I would also check to see if “BY CHANCE” a wire came loose from under the dash. The headlight switch is working or the headlights/tails wouldn’t be on,so you’re getting power,just not to the cluster somewhere.
Is anything else out in the car? Like the clock,map light,radio?
Might be a fuse under the hood.
happened about a week now after the right headlights/signal blew i checked the bulb then thats when it happened and then i took out the dash to check if dimmer switch is loose or anything but its not i assembled everything back
mmmmm…my headlights do turn on and so does my fog lights just not the cluster and i thought cluster and tailights was together?
and no nothing else is out of the car
corner light/cluster lights/taillights are dead
only headlights and foglights works
The right side blinker blew out?
I wonder if you put the wrong bulb in or there is a fuse you missed. You have a test light at all? I would recheck all the fuses with the test light,check both ends of the fuses tho,not just one side.
Also see if the right side parking/blinkers or working as well,might be a wire grounding out on you.
[QUOTE=tino;2200648]corner light/cluster lights/taillights are dead
only headlights and foglights works[/QUOTE]
This is going to be a fuse bro,check all the ones under the hood with the test light if you have one. And also check all the fuses under the dash as well. Now where getting somewhere…lol
thx…ill try that and ill let u noe how it does
Any news yet??? Did you fix it on not?
Ground?!
after reading this do you have a after market deck in there? did you just put one in or move any wires down there if it is aftermarket?
