Cluster lighting
So my cluster as of late looks dimmer than usual at night, even on max cluster lights.
The light seems brighter towards the higher end of the tach and the lower mileage on the speedo, could it be that just some of the lights burnt out, or what could it be.
Thanks,
Coz
it might be normal, because the g2 cluster is rather dim compared to the newer model integra/civic, but there’s always a fix for that. But after a long while the bulbs do start getting dimmer. if you have a picture of you cluster lights at night, i’m sure we’ll be able to tell you if you have blown bulbs or not.
here’s a link to making the cluster amber, but if u’re not into that look, you can just replace it with regular bulbs.
http://g2ic.com/forums/showthread.php?t=101047
Yah I know they’re usually dimmer than most, but this is lower than usual that’s why I’m asking before I pull the damn thing and I unhook the speedo cable.
Looks like I’ll have to though. Thanks for the good looks.
Coz.
yeah n replace dem wit LED’s so ull neva have to pull dat pain in da ass out again…fuck da spedoo cable its a nightmare - C.R.E.A.M.
