i have jdm one piece headlights put them in and wired them up and they worked like they should for 2 months then my yellow lights went out and both sides at the same time my gauge cluster lights went out?
started with the cluster took the lights out and they looked fine but i replaced them anyways, still nothing so i went to look ay my headlights took them out and they look fine, moved on to the wiring took it apart and rewired it still nothing.
at a loss here this car is starting to be more of a hassle than a blast to drive
Have you checked the fuse(s)?
Dash lights- Fuse 11 - 15A, [hot when park/head lights are on] in under dash fuse box.
I assume you mean fog lights when you say yellow lights or are you talking about the amber park lights?
The cars park/running lights are on the same fuse as the dash lights.
The dash lights get there ground from the “Dash Lights Brightness Controller” so if the fuse is good you will need to check it. 94
