cluster lights keep going out !
so im driving down the street the other night and my cluster light randomly went out…i got home and checked my fuses to just make sure, and found out one was blown, replaced it and they worked again…well they went out again same fuse same problem…
was wondering if anyone has had this problem before or if its common…im sure its water leaking on my taillights or somthing or a wire thats shorting out just wanted to know if it could be somthing else that i havent heard about ?
just did a second search and stuff actually came up this time…im going to replace my switch and see if that helps…
did the problem stop after chaning the switch?
