Cluster stopped working
so yesterday my cluster just stopped working…the only lights that come on is the high beam light and battery light…no speedo…RPM…or temp…any ideas?
Do your tail lights work cuz mine goes out some times with my tail lights and its a loose fuse.
i checked all the fuses under the hood and tail lights work
Did you check the instrument fuse, fuse 23 -10A (90-91) 7.5A (92-93) in under dash fuse box.
Don’t just eyeball it use a meter or test light or replace it with a known working one. 94
checked all the fuses and all good…the only lights that come on is the battery and the highbeam…its not the battery because i changed it with a new one
You will need to do some testing, you will need a multimeter or at least a 12V test light.
Pull the cluster and test for 12V+ on the black/yellow and yellow leads, [with ign. switch on].
Test the black lead for ground. 94
