Cluster Swap..
I changed my guage cluster because my gas gauge reads wrong…
the problem is that when i switched it, the gas gauge still reads wrong and fluctuates slowly up and down…
also when i put amber light bulbs, the 3 194 bulbs dont light up
any ideas?
i also dropped the gas take and switched it out…still not working
have u checked the gas sending unit? any open wires?
and for your bulbs, are they led or just normal bulbs? led can only go in one way since there polaritied or w/e, if they’re normal check to see if they’re blown or not… you must also change out the other small bulbs, three of them forgot what sizes…
Are you talking about the wires that run to the fuel pump?
i also changed the 3- 24s and the 3- 194s…
I’m having the same problem, Did you figure it out?
