Clutch and Flywheel
Im gettin my B16A SIR1 swap in a few days and before i put it in i want to know what clutch and flywheel i can go with for the transmission. Will a 90-93 Teg clutch and flywheel work or will I need to find something else?
All B-series flywheels are interchangable. Just use what ever is more available for you.
There is no such thing as 90-93 clutch. The 91 and older tranny’s have a smaller spline than the 92 and younger. This means a clutch from a 92 tranny will not work with your 91 or older B16 tranny. With the tranny you’re using, you’ll need a clutch for a 91 and older.
-Steve
yup, i concur! steve’s info is correct.
Ok thanks for the help on that. I can find a clutch to fit but I was
worried I wouldnt be able to find a lightweight flywheel that fit.
ya i got the jun flywheel…only 9 #s…i like it alot…but getting traction on the streets is a b!tch!!:argh:
