Clutch Cable Adjusting for a swapped B16 Tranny and a Stage 2 Clutch
No matter how much I loosen the cable (or tighten it for that matter) my clutch catches almost the exact moment you back off of the pedal. It doesnt seem to catch anywhere else no matter how I adjust the cable. Just threw in the F-1 Stage 2 clutch kit with a 9lbs flywheel on a B16 tranny. The transmission cable is brand new.
You also need to adjust the clutch pedal. There is an adjustment screw on the back, should be like 7" from the back side of the pedal to the floor.
That I did not know. Is there a write up on this? I cant seem to find one on the site? If not, if I could get some info on it, and I will make a video and a write up for it.
Solved the issue. Cable was caught near the firewall. Tightened it up, made sure the clutch wasnt being rode on and its working fine now :slight_smile:
Well heres a link:
worth checking to make sure it’s right on.
