how do you disconnect the clutch cable from underneath the pedal?? any help would be much appreciated…
loosen the tension via the adjusting knob near the tranny. when there’s enough slack, check underneath the pedal and unhook it.
try to push it up and towards the back of the car. should pop right out.
You’re going to need a long set of needle nose pliers to unhook the cable from the pedal.
First you unhook the cable from the tranny.
Go under the pedals face up, then push the pedal in and use the pliers to unhook the cable.
thanks guys…
can anyone tell me how to remove the clutch cable from the bracket for rerouting? i’ve been searching and havent found a write-up or a how to. i figured it was cut and dry as screwing the knob back pulling it up and out and putting it below the IM and just doing that
