OK i just installed my new clutch. I get into the drivers seat to start it back up and i notice that the pedal has this tension up high then once its in all the way its way soft. When i shit i have to raise the pedal all the way back to the top where the tension is at. I have tried adjusting the cable many times and the pedal just gets more soft. I want to know if you guys think i stretched my cable or what?
Sounds like an interesting procedure for the old #2.![]()
What I would check first is the arm coming out of the transmission. Unhook the cable and move the arm by hand. If it doesn’t move smoothly then Its possibly a bad throw out bearing. If not then try adjusting the cable some more. Its possible that there is a bind or like you suggested a stretch in the cable. I like to replace the cable along with the clutch for good measure. On my first clutch job I burnt it up quickly because of a bad cable. Good luck.
