Clutch flywheel arp Crankshalf
Hi for sale is a brand new competition clutch stage 3 kit with release bearing pilot bearing and alignment tool in original packaging.
The kit is for 1992 1993 gsr and Ls. $300
Competion clutch street light flywheel new $120
Arp flywheel and pressure plate bolts new
b18 gsr arp head bolts like new used
b18 gsr Main head studs like new used
2 - b18 Ls 89mm crank $100 each
Eagle Ls 89mm crank like new . Crank was assembled in a motor that required a aligned hone. It was removed and replaced by a lightweight scat crank , so I don’t need it
$450
Used Fidanza light weight flywheel 7.5lbs. It will need resurfacing
$80
Used Typhoon intake manifold for b16 b17 and
type r head. $80
B17 block
Comes with
Crank main caps and bolts. Rods and piston
go
Email me for pics. Gerardguerra454@gmail.com
Bump
