I was wodnering if anyone has ever bypassed their switch so that you didnt have press in the clutch to start the car? If so how on a 1991 Acura Integra LS?
Thanks
Matt
you can bypass it, but i don’t think your cruise control would work cause it would think the clutch was always on the floor…
you can bypass it at the relay by one of two methods:
1 Cut blk/wht pin 2 and blk/red pin 3 and connect the two wires together. The blk/wht is from switch. The blk/red is to starter. This bypasses relay completely.
OR
2 cut blk/blu wire pin 4 and connect relay side to ground. This will energize relay whenever there is a crank signal.
The cruise control wont be affected by either one these methods.
