Hello i was wondering where i would find the wires for the clutch interlock switch. I want to put it on a manual switch because the neigborhood has been getting bad my buddys teg got stolen a few weeks ago and i thought this would be a great anti theft device
The leads are at the CIS plug, [black and black/blue] or you can pick up the supply lead, [black/blue at the starter relay.
With that said I would not do a “kill switch” on the CIS unless it is an added layer, by itself it is easily bypassed, any kind of starter kill on a standard is easily bypassed, install a switch on the ground,[ black] to the PGM-FI Main Relay instead, it is also a low current ground, [no more then 250mA] so a small easily hidden 1A switch can be used.
A kill switch on the PGM-FI Main Relay will cut power to the fuel pump, fuel injectors, ECU/ECM and a few engine sensor/solenoid valves. 94
dam that would be way better where is it located at
