clutch issue help
i pulled my tranny and clutch because of weird noises and clutch engagement issues . turns out one of the spring in the center of the clutch disk popped out and was just hangin out in the tranny causing the engagement issues but i want 2 know why would the spring fall out of the clutch disk thaks for your help in advance
Because you’ve been doing 4k rpm clutch drops probably.
That’s one of the most common forms of clutch failure and is not a for sure indicator that the clutch has been abused. If you inspect the disk you’ll see that the tabs which old the spring in place are probably worn down, worn away or have broken off. Don’t worry about it, just install the new clutch.
But!
It’s much more commonly found to occur as a result of trying to get that “mad spin off the line, yo”.
[QUOTE=Patch;2092952]But!
It’s much more commonly found to occur as a result of trying to get that “mad spin off the line, yo”.[/QUOTE]
If you say so.
thanks
ok thanks for your imput and i do launch hard at the track but not at 4 grand but yea ill just put the new one in thanks
4 grand, 3 grand, 2 grand, 150000 grand, it’s all the same bro.
o really?:umno:
this happen to my clutch amonth ago and not from spinning tires i was at a stop sign and took off normal and my clutch popped and starting making a whinning noise as i drive…
holy shit dude that sucks. i usually launch mine at 5k at the track the key is to make sure you pre load but in 8 years and god knows how many clutches aint seen that but i have seen the disks crack. i do alot of work for friends so im suprised i aint seen that
this is not always true. i drove my car for two years and never lauched at the light or tried to do mad jdm burn outs lol, but my spring did that. all my friends made fun of me cause i drove like a grandma.
yup, I never did high rpm clutch drops or tracked the car but that happened to me on the old teg.
a few years ago mine was like that too when my mech replaced the clutch.
i think the spring popped out in my clutch again cause the pedal is getting abnormally hard to push down (just like the first time) though it could also be my clutch cable which sounds like a whale. So much for teaching newbs how to drive stick in my car :frowning: Pretty sure their jerky starts and clutch drops did it in. the clutch is what… only 20k miles old?
