for some reason my clutch is not working… it has dropped completely to the floor u can move it up n down with u hand but doesnot retract normally as it should… to my surprise the car starts with no problems so im guessing maybe the cable is lose but idk… plz ill stake any suggestions
snapped cable?
th cable could have broken or maybe just come off its bracket. pop the hood and take a look you can tell just by looking
The cable appears to be in completely good working condition… After checking the bracket the connects the cable to the tranny i realized the clutch is not disengaging … Like it normally should hints why the car still turns on … Is it possible mayb my pressure plate is bad or maybe my flywheel is bad …
are you sure the adjusting collar isn’t stripped? if the cable is in perfect working order, the transmission will have to come out. probably either the pressure plate fingers or the release fork
i replaced the clutch cable and everythings good thanx g2ic
