ok so wat happend i was on second gear gas it to like 5000 rpm try to shift to third and gear didnt go in , i try to put it in gear again then this time it let me put on gear n i gave the car a gas and it didnt wanna go anywhere i tried any gearr same reaction it lets me put into gear i give it a gas and car wont go anywhere and now the car makes a wierd noise that it didnt just to do when this happen…i feel that somethin is not grabbin… most of the ppl i tell this problem tells me its the cluth iono if the might be right or wrong but for myself i think its the same thang… or can it be my tranny?? but if it was my tranny i wouldnt be able to put it in gear when the car its on or off right?..well let me know wat you guys think thankz!!
does anybody as an opinion on this post??
have you noticed any difference in the feel of the clutch pedal?
i dont feel any change on the clutch pedal…it feels the same as before…
i think youve answered your own question. your clutch disc could very well just be worn out and needs replacing
thankz for ur opinion @ anthony.
My car is having kinda the same problem it’s really hard to go into gears I think is the clutch but will try to change the ATF first before tearing down the transmission.
if it’s difficult to get the shifter into gear, the issue could be the throwout bearing and/or the release fork spring. once you get the car into gear, can you get it to move?
Hey I had the same problem. The shifter was hard to get in gear and when it was in gear it wouldn’t move. New clutch installed like 4 months ago from this one shop local here which never go back to cause they suck ass…don’t wanna put them on blast but I should though…Oh yeah my transmission ended up blowing up with 2 holes in it…Also clutch pedal was easy to push in/out…
shops like that should be put out of business. you might be able to take legal action to get them to pay for their mistakes
